Air carbon arc gouging is one of the most versatile and productive metal removal processes available — capable of gouging almost all metals quickly and with minimal equipment investment. The process uses the heat of a carbon arc combined with a compressed air jet to melt and blow away metal, creating grooves, removing weld defects, back-gouging weld roots, and preparing joints for repair. It is fast to learn but requires correct technique and equipment selection to achieve clean, consistent results. This guide covers electrode and torch selection, positioning, arc striking, and the key technique variables that determine gouge quality.
The process uses a carbon or graphite electrode held in a specialised torch to generate an arc between the electrode and the workpiece. The intense arc heat melts the metal at the contact point, and a jet of compressed air — delivered through holes in the torch head adjacent to the electrode — blows the molten metal away continuously. This creates a controlled groove or cavity in the workpiece.
The process works on mild steel, stainless steel, cast iron, aluminium, copper alloys, and nickel alloys — making it far more versatile than oxy-fuel gouging, which is limited to steels. It is widely used for back-gouging weld roots before welding the reverse side, removing defective weld metal before repair, preparing bevels on plate edges, and removing unwanted weld reinforcement.
Electrode selection is the first and most important decision in air carbon arc gouging. There are three types:
Electrode diameter controls groove width and depth capacity. Key rules:
Gouging torches contain a swivel head with compressed air ports that direct the air jet alongside the electrode toward the workpiece. Most torches are air-cooled; water-cooled cable assemblies are used for heavy-duty, high-current applications where extended continuous gouging is required.
The swivel head allows the electrode to be positioned for different gouging orientations — flat, horizontal, vertical, and overhead. Confirm that the torch is rated for the current and electrode diameter being used before starting — undersized torches overheat rapidly and fail prematurely.
Always turn on the compressed air flow before striking the arc — not after. The air jet must be flowing before the arc is struck to immediately clear molten metal as it forms.
Correct setup before striking the arc prevents the most common gouging problems:
Strike the arc by lightly touching the electrode tip to the workpiece surface. When the arc strikes, do not withdraw the electrode — maintain contact and allow the arc to establish. Withdrawing the electrode after striking extinguishes the arc and requires restarting.
Air carbon arc gouging typically operates between 35–55 volts. The arc should be loud and aggressive. A muffled or quiet arc indicates insufficient voltage — this leads to carbon deposits in the groove and contamination of the base material. If the arc sounds muffled, increase voltage before continuing.
Hold the torch so the electrode slopes back from the direction of travel at 35–45 degrees to the workpiece surface. This angle positions the compressed air jet to blow past the electrode tip and carry molten metal forward and away from the groove continuously. An angle that is too steep (too upright) traps molten metal behind the electrode; too shallow reduces penetration and groove depth control.
Travel speed is the primary control for groove depth:
Maintain a short arc length throughout the pass — move forward at a speed that keeps pace with electrode consumption. A short, stable arc produces a smooth, consistent groove. If travel speed drops too low, the arc length increases, the arc becomes unstable, and groove geometry becomes irregular.
Always move the electrode forward in the direction of the gouge — never reverse or back up during a pass. Reversing direction pushes molten metal back into the groove and creates carbon deposits that contaminate the base material. Once the arc is established and moving, maintain forward progression continuously until the pass is complete.
Keep your head positioned behind the arc, not over it — this improves visibility of the groove line ahead of the electrode and keeps the operator clear of the expelled molten metal and arc flash.
When back-gouging a weld joint to expose the weld root before welding the reverse side, focus on the weld seam line visible ahead of the electrode. The line where the two base materials meet provides a natural guide for the gouge path. Maintaining focus on this line ahead of the electrode — rather than on the arc itself — gives better control over groove location and depth.
After gouging, clean the groove thoroughly by brushing and grinding as required before welding. Any carbon contamination remaining in the groove from an inadequate air pressure or technique error must be removed before depositing weld metal — carbon inclusions cause porosity and can lead to weld cracking. For guidance on welding procedure qualification after repair gouging, see our article on WPS and PQR management.
