Correct flux management is one of the most overlooked factors in submerged arc welding (SAW) quality. Flux that has absorbed moisture — even in small quantities — introduces hydrogen into the weld pool, which is a primary cause of hydrogen-induced cracking (HIC) in high-strength steels and restrained joints. The consequences of poor flux handling are not always immediately visible: HIC is a delayed failure that can develop hours or days after welding is complete, making it particularly dangerous in structural, pressure vessel, and offshore applications.
This guide covers the three key functions of flux, how flux baking works, and the specific storage, handling, recycling, and rebaking requirements for Exaton SAW fluxes. For guidance on flux-cored and metal-cored wire selection, see our Flux-Cored and Metal-Cored Wire Guide.
Before addressing handling and storage, it is worth understanding what flux actually does — because the handling requirements flow directly from these functions and what compromises them.
Flux removes oxides, grease, moisture, and other surface contaminants from the metals being joined. Oxides on the base metal surface prevent the molten filler metal from bonding effectively — flux dissolves these chemically, creating a clean, reactive surface for the weld to form against. Even a brief period between pre-cleaning and welding can allow re-oxidation to begin, which is why flux-protected processes such as SAW are particularly valuable on scale-prone materials.
During welding, flux forms a protective barrier — either as a slag layer or, in SAW, as a physical granular blanket — that shields the molten weld pool from atmospheric oxygen and nitrogen. Without this protection, the weld pool would rapidly oxidise, producing porosity, inclusions, and a mechanically compromised joint. In SAW, the granular flux blanket completely covers the arc and weld pool, providing both atmospheric protection and thermal insulation that contributes to the controlled cooling rate of the weld.
Flux acts as a wetting agent, reducing the surface tension between the filler metal and the base metal. This improved wetting allows the molten filler to spread evenly and form a strong metallurgical bond across the joint. Flux also lowers the effective melting temperature of the filler, enabling it to flow into tight joint geometries more easily and fill the joint completely.
In submerged arc welding, moisture absorbed by flux during storage or handling is one of the most serious process variables. When moist flux is heated in the arc, the moisture dissociates and releases hydrogen into the weld pool. This dissolved hydrogen migrates to points of high stress concentration — typically the weld root, the fusion line, or the HAZ — and can cause cracking that develops well after the weld appears sound.
Hydrogen-induced cracking is particularly dangerous because:
Flux baking removes absorbed moisture and volatile substances by subjecting the flux to a controlled heating cycle, restoring it to its optimal condition before use.
Exaton fluxes are manufactured with carefully controlled raw material selection and optimised production conditions, ensuring a guaranteed as-delivered moisture content from the factory. To maintain this condition for as long as possible, the following handling and storage requirements must be observed.
Unopened flux drums must be kept under the following controlled storage conditions:
SAW flux is typically recovered and recirculated during welding. To maintain flux quality through the recycling process:
When handled and stored correctly according to the requirements above, Exaton fluxes can generally be used as delivered without rebaking. However, rebaking is recommended in two situations:
ESAB's submerged arc welding flux range is available in the BlockPac™ format — a high-moisture-resistance packaging system for fluxes such as OK Flux 10.65 and OK Flux 10.66, designed to maintain flux condition during transport and storage and reduce the frequency of baking required in controlled environments.
For stainless steel and nickel alloy SAW applications, OK Flux 10.99 is a neutral agglomerated basic flux designed for austenitic stainless steels and compatible with nickel-based alloy wires for demanding corrosion-resistant applications.
For SAW wire selection guidance, see our Welding Consumables Selection Guide or contact your local ESAB representative.
Why is flux baking important in submerged arc welding?
Flux baking removes absorbed moisture that can introduce hydrogen into the weld pool during submerged arc welding (SAW). Excess hydrogen increases the risk of hydrogen-induced cracking (HIC), particularly in high-strength steels, thick sections, and restrained joints. Proper flux baking helps maintain weld quality, reduce cracking risks, and ensure consistent welding performance.
What temperature should SAW welding flux be baked at?
The correct flux baking temperature depends on the manufacturer's specifications. For Exaton SAW fluxes, the recommended rebaking temperature is 350 ± 25°C for a minimum of 4 hours. Flux should be spread in shallow trays with a maximum layer depth of 50 mm to ensure uniform heating and effective moisture removal.
Can submerged arc welding flux be reused or recycled?
Yes. SAW flux can be recovered and recycled if contamination is properly controlled. For Exaton fluxes, at least one part new flux should be added for every three parts recycled flux. Recycled flux must also be sieved to remove slag fragments, mill scale, and other foreign materials. Compressed air used in recycling systems must be free from moisture and oil to maintain flux quality.
When does Exaton welding flux need to be rebaked?
Exaton SAW fluxes can generally be used without rebaking when stored and handled according to the manufacturer's recommendations. Rebaking is recommended when flux has been exposed to excessive humidity, damaged packaging, or improper storage conditions. It may also be required for critical applications demanding very low hydrogen levels, such as H5 or H4 classifications. After rebaking, unused flux should be maintained at 150 ± 25°C until needed.
