Modern fabrication workflows depend on dozens of closely interlinked processes — from plate nesting and cutting through to welding, quality assurance, and documentation. Disruption at any point has a direct knock-on effect across the entire chain. ESAB's InduSuite portfolio of digital software solutions gives fabricators a single platform to monitor, control, and optimise every stage — regardless of equipment brand.
InduSuite is ESAB's brand-agnostic portfolio of welding and fabrication software applications. It covers the full fabrication workflow — cutting, welding, quality assurance, documentation, fleet management, and robotic programming — on a single connected platform. Because InduSuite is brand-agnostic, it works with ESAB equipment and with other manufacturers' machines, making it practical for mixed-fleet operations.
InduSuite delivers three core benefits:
Finding and retaining experienced welders is one of the most pressing challenges facing the fabrication industry. As experienced welders retire, the pipeline of qualified replacements is not keeping pace. InduSuite helps manage this challenge by digitising welding procedures, guiding less experienced operators through WPS (Welding Procedure Specification) compliance, and reducing reliance on individual expertise for consistent results.
Clients demand adherence to WPS requirements, and quality control testing is a constant overhead. With real-time weld data monitoring, InduSuite allows quality managers to identify non-compliance during welding rather than after — reducing the need for destructive testing and costly rework.
Large projects and tight deadlines create constant pressure to cut and weld faster. Without data, productivity bottlenecks are difficult to identify and even harder to address. InduSuite makes performance visible — by shift, by operator, by machine, and by material — so decisions are based on evidence rather than assumption.
Downtime can occur at any stage of a project. InduSuite monitors equipment health in real time, enabling service and maintenance teams to identify issues early, plan preventive maintenance, and avoid unscheduled stoppages — from anywhere in the world.
Manual documentation is time-consuming, error-prone, and increasingly burdensome as regulations evolve. InduSuite automates documentation of welding parameters, operator qualifications, and procedure records, replacing spreadsheets and paper-based processes with a fully traceable digital system.
WeldCloud Productivity connects your welding power sources — ESAB and other brands via the WeldCloud Universal Connector — to a secure, cloud-based welding analytics platform. It logs current, voltage, wire feed speed, and other key parameters for every weld seam produced, allowing production and operations managers to:
WeldCloud Productivity supports MIG/MAG, TIG, Stick, and SAW welding processes. The WeldCloud Universal Connector extends connectivity to virtually any brand of welding power source, making it practical for operations running mixed equipment fleets.
WeldCloud Notes is a cloud-based platform for managing all welding documentation — Welding Procedure Specifications (WPS), Procedure Qualification Records (PQR), and Welder Performance Qualifications (WPQ) — with full code compliance checking built in. Supported standards include ASME IX, AWS D1.1, AWS B2.1, ISO 15614-1, and ISO 9606-1.
WPSs written in WeldCloud Notes are automatically checked for compliance, eliminating the risk of procedural errors that only surface at audit or inspection. Role-based permissions and multi-company support make it suitable for large corporations and smaller fabrication businesses alike.
WeldCloud Assembly is an IoT-enabled cloud platform for tracking every project, part, and weld through a fabrication facility. It connects directly to welding equipment on the shop floor to capture weld parameters in real time, and alerts supervisors immediately if any weld falls outside WPS requirements. Drawings, base materials, filler metals, welder assignments, inspector records, and NDT requirements are all maintained in a single traceable system.
WeldCloud Fleet is designed for service and maintenance managers responsible for larger fleets of welding equipment across one or multiple sites. Key capabilities include:
CutCloud is a web-based data management platform that automatically reports on the efficiency and productivity of your cutting operations in real time. It monitors how cutting machines are performing, tracks uptime and downtime, and helps predict when maintenance is required — from any location. For operations running ESAB plasma or oxy-fuel cutting systems, CutCloud provides the cutting-side equivalent of WeldCloud Productivity.
COLUMBUS is ESAB's powerful CAD/CAM nesting software for plasma, oxy-fuel, laser, and waterjet cutting systems. It optimises part nesting to maximise plate utilisation, reducing material waste and cutting costs. Key features include:
InduSuite has delivered measurable improvements for fabricators across Europe and beyond:
Parat Halvorsen, a leading Norwegian manufacturer of industrial boilers, transformed its production process with ESAB's advanced plasma cutting technology and digital solutions. The results included faster cutting speeds, significantly improved cut precision, and a safer, quieter working environment — with notable reductions in grinding time and noise levels. Dome fabrication accuracy improved, and the overall workflow became more efficient from plate to finished component.
Read the full Parat Halvorsen case study →
InduSuite applications are available as cloud-based subscriptions, requiring no on-site servers or software installation. COLUMBUS and OCTOPUZ (offline robotic programming) are installed applications for operations that require local deployment. All applications are available individually or as a bundled suite.
To explore the full InduSuite portfolio, request a demo, or discuss which applications are right for your operation, visit the ESAB InduSuite page or contact your local ESAB representative.
Explore more ESAB articles on welding data, digital solutions, process optimisation, and improving fabrication productivity.
What is welding software, and how does it improve fabrication productivity?
Welding software helps manufacturers monitor, manage, and optimise welding operations using real-time production data. Solutions such as ESAB InduSuite track welding parameters, equipment performance, arc-on time, and material consumption. These insights help fabricators identify bottlenecks, reduce downtime, improve weld quality, and increase overall production efficiency.
What is ESAB InduSuite, and what applications does it include?
ESAB InduSuite is a portfolio of digital software solutions designed to connect and optimise fabrication workflows. It includes WeldCloud Productivity for welding analytics, WeldCloud Notes for WPS and PQR management, WeldCloud Assembly for production traceability, WeldCloud Fleet for equipment monitoring, CutCloud for cutting performance, and COLUMBUS for CAD/CAM nesting optimisation.
Can ESAB welding software work with equipment from other manufacturers?
Yes. ESAB InduSuite includes brand-agnostic applications that support equipment from multiple manufacturers. For example, WeldCloud Productivity uses the WeldCloud Universal Connector to collect welding data from different brands of power sources. This allows fabricators with mixed equipment fleets to centralise performance monitoring and reporting.
How does welding software help with WPS compliance and weld traceability?
Welding software improves compliance by digitally managing Welding Procedure Specifications (WPS), Procedure Qualification Records (PQR), and welder qualifications. Applications such as WeldCloud Notes help verify documentation against applicable standards, while WeldCloud Assembly captures welding parameters and identifies deviations from WPS requirements. This reduces manual documentation, improves traceability, and simplifies quality audits.
How can welding data analytics reduce manufacturing costs?
Welding data analytics helps manufacturers reduce costs by identifying inefficient processes, excessive material consumption, equipment downtime, and opportunities to improve arc-on time. Real-time monitoring also supports preventive maintenance and earlier detection of welding quality issues. By using production data to optimise workflows, fabricators can reduce rework, improve resource utilisation, and increase productivity.
